LEDs on parking/turn signal lights fast flash
dp1225
I know someone on here posted this up but was wondering if there's a specific kind of LED I have to use to put in my parking/turn signals so they don't flash fast.
Thanks for the help guys
Ont240
LED's don't create enough load.
Change the flasher relay to an electronic one
dp1225
Would the escalade relay work since they have LED tail lightsx
Ont240
Not sure on your application.
My experience was with older canister style flashers.
google Napa parts or do cross reference on Gm part#s
Check out napa# 44010
samotahoe
San Diego, Cali
you can pick up a load equalizer from you local parts store for a few dollars and just hook it up in line with the turn signal wire. this will prevent the fast flash, but if the bulb goes out it will not flash fast anymore
