K&N FIPK and delayed starting
ScottyUSN
OKC, OK
I.m not impressed with the materials provided with the K&N kit. Non-the-less my 2000 Tahoe starts slower since install (2 cranks instead of one).
The Tahoe has 90K miles, so I'm going to change plugs before I lay the blame on the new intake. Anyone running a K&N or other aftermarket intake have simular issues?
-Thanks
JennaBear
CA
Double check the coupler at the throttle body, this is a common issue with the K&N CAIs. Definitely sounds like you have an air leak. Either that or your MAF is really dirty.
Polecat
Stillwater, OK
if your MAF is dirty, get some spray cleaner from NAPA, worked to fix my problem, or at least help fix it.
