I need to replace the rubber stops on the front section of the frame above the lower control arm. Do you guys know the right GM part number for these? The one I have is 15835666, but I can't find an exact picture of them to know if that is the right number.
It is on a stock lift 1999 Chevy Tahoe 4DR 4WD.
Also, I seem to remember reading in here somewhere that the lower control arm should be touching these stops slightly in order for the torsion bars to work properly. Is this true or should the control arm not touch these rubber stops?
Thanks.
Thanks.
