Jimmie48
Hi Guys,
Just a little note about my latest problem with my 07. I had a leak in the rear main seal where the tranny links to the back of the engine that is being replaced under warranty. Also my door molding is being replaced because the 3m tape started to come loose and is starting to bend the molding. Also the tire pressure monitor went off for no reason and says it needs to be serviced, so she will be in the shop for a couple of days. The service advisor told me that this is not a common problem(rear main seal) but every new Tahoe especially the 07's are coming up with issues here and there. It was not a large leak just a slow saturating leak and would not have been found unless I saw it while just inspecting the undercarriage of the car. SO you guys may just want to check it out just in case. Otherwise I have enjoyed the car immensely and will continue to do so when I get her back. Cheers
