I have a 2001 chevy tahoe and my instrument cluster just died while driving. 130k so speedometer, odometer, all gauges.
Checked all connections on the wiring harness all tight. I also checked the grounds and positive wire on the harness all is good. checked the ground under the hood and its fine.
The only light that works is the check ingine light, turn signals. when I turn the key into the first position the odometer lights up until I put it into the next position to start the truck. The truck starts I can jiggle the key ring area and no issues with the cluster. I replaced the cluster and still dead. I think its the BCM but Im not sure.
Every once in a while the radio clock will reset back to noon. And the abs light has come on and gone off pereodicly. now just the check ingine light stays on. I know I need a fuel pump sensor but thats been bad for over a yr with no problems. Also the security light is on very often . Please can anyone help
I am thinking about getting a new BCM let me know.
