Installing Power 6-way Seat in Manual Passenger Tahoe LS??
Davidc21a
Hi guys,
I have a question. I have a 2007 Tahoe LS with Only the 6 Way Power Driver's seat and no passenger power seat. I was able to locate a 6 way Passenger seat that has power to replace my Manual Passenger seat. Any ideas on how difficult this would be to connect? Any advice or How to's? Any info would be greatly appreciated.
Thanks
clkelley
Moderator
Galax, Virginia
Welcome to the neighborhood!
To make sure it will work, remove the passenger seat and plastic door step shield, and kick panel (they should just pop right off with a cheap interior parts removal tool from your local auto parts store.
Once out peal the carpet back far enough to see under where the seat should be, if you have wiring and a plug under there for the power seat then it is just a plug and play switch. If not you need to go to the dealer and have the parts guy look in the computer to see if they can order that portion of the harness to be upgraded.
tonymac617
Boston, MA
IF your handy, you can go to the junk yard, find an LT in your year range and pull the harness. Go up far enough to allow you extra wiring in case you need to run it or make a mistake and need to re-cut and splice. Im not entirely sure if theres a module under the power seat that you would also need, but I can check mine and let you know.
