I'm new owner. Need help on nav selection
Tahoez
Ny
Hi. I want to install an in dash navigation unit. I have the Bose speaker system. Is every gps comparable with Bose ? Anyone have pics of them installed? And which units do you recommend. Thanks a lot.
JayGee
Im assuming that by comparable you mean compatibile, then yes but you do need a GMOS-04 wiring harness, which will run you an extra $80. My tahoe had the Bose I attempted to use one of this adapters and had TERRIBLE results! It did not work the way it was supposed to, I ended up tearing out and bypassing the factory amp.
But it seems as though alot of people have had similiar problems, and a few have had none with the GMOS-04, either way good luck!
Sirjag
its a pain in the ass bud. i have the tahoe LT (2011) with bose and standard radio..i ended up with the rosen unit, its the ONLY plug and play availible, period. if not that then the kenwood 9XXX serise. this is especially true if you need dual channel audio (rear entertainment system).
its suck...but the rosen unit works very well now. most of the bad reivew out there are from the older 2010 and before units..
good luck,
jag
