huge YUKON suspension problem!
CK805
I have a 2005 yukon 4x4 slt. im having some big issues with suspension. I changed all 4 shocks, but the truck still rides like crap. I also noticed that the rear suspension sits lower and sags. like it has a 2" drop. if I hook up a small trailer to it then its really slammed. I was told i needed new rear springs.
if so. where can i find some oem new or used. Or oem height but a liitle more heavy duty. if this is not the problem. can anyone tell me what it is.
DarkTahoe00
IN
You could try looking on Ebay for some or one of the forum's vendors. you also could try stylin trucks.com.
You can install some air spring helped bags that would compensate for the sag, or get used stock springs off eBay. Someone on here should have some stock springs or h2 springs will give you a bit of lift and higher spring rate.
667theneighbour
If this was my problem I would try to find out why a 2005 model is sagging in the rear. My 2004 is fine. You should check out the history of the car. Have previous owners had a lot of load in the rear, trailers with too much weight on the hook of the car etc. It's always nice to know the whys. :)
