hub nut
maplewood6160
2008 Tahoe 4x4 can't get hub nut loose. compressor only goes to 150. Broke a 1/2 breaker bar with impact socket (used a 3 ft pipe) someone told me it's 172ft lbs. on the nut. anyway i can't get it off thanks
rockenthebowtie
Any time I want
What kind of wheels do yo have on it... if you put the tire back on and the center cap off does it expose the nut if so spray all around the nut and axle and let it soak the like I said put the tire back on park brake trans in park and get a good quality 1/2 braker bar and try it again after letting it soak with some PB oil penatrent
maplewood6160
vehicle sitting on ground brake on. No cap on nut. nut is exposed when you take cover off. used whole can of spray even tried trans fluid mixed with acetone. used a s/k breaker bar.Just won't move/ hate to pay someone to do them. maybe 3/4 drive
