How to reset the ECM
PotentialTahoe
I was wondering how do I go about resetting the ECM, will the reset also clear all the trouble codes temporarily. I am installing the speed sensor and want to reset the ecm prior installing and testing the new sensor. Thanks for the help.
peterey2
get it hooked up to a code reader or scanner and erase all your codes.
peterey2
theyll still be held in the computer's memory for codes but thatll work too.
hapyspaz
Austin, Texas
While the engine is running, open the fuse panel under the hood, pull out either ECM A or ECM B fuse. Engine will die. swap the placement of the fuses. restart engine. This should reset your ECM if you dont have a scanner or code reader to reset it.
