How to remove this cover??
bigredtex
DFW, Texas
Ok, need to tap into the ignition wire but can't figure out how to get this cover off. It's under the dash on the driver's side. It has two arrows at top pointing to the sides, so I've tried depressing these and pulling (among other things) and nothing seems to be working. It shouldn't be that difficult, but somehow I'm making it so.
Someone please throw me a bone here so I can feel adequately stupid after you tell me how easy it is.
veetek
I believe those are the two tabs on the side that you have to depress than pull the top part to tilt and remove
rockenthebowtie
Any time I want
That circle in the middle is a retainer clip you slide a forked door panel removal tool under the circular part of the retainer clip so that the tool is between the clip and the cover and pry up ward once you get the retainer clip off it should come right off
