How often....
sgmstr
do you need to change your transmission oil? The dealership I've been going to says every 30K miles. Another says every 50K miles. The manual says every 15K miles I believe. FYI, I live in Los Angeles area so I can't follow maintenance schedule under normal driving condition.
Thanks in advance.
73shark
KC, MO area
Per the owner's manual (which you should check to be sure), tranny fluid and filter s/b changed at 100K for normal service and 50K for severe service.
TAHOE FREAK
Keep in mind the manual doesn't reflect real world or should I say harsh driving conditions, which is what LA driving really is, I would be somewhat Conservative on the numbers.
07SuburbanLTZ
North Jersey
I was once told by an old wise mechanic that you should service your trans at 40,000 and then never touch it again.
