pyramid jacks right on the frame just a bit behind the front tires if i had to guess it would
be under yer feet ify you were sitting the front driver or passanger side there shoudlnt be anything in the way this is were you should jack up just about any suv or truck also the manual shows were to jack up the vehicle wich is were i said crank up the jack then put a pyramid jack right next to it and let her down chalk the back wheels for safety do the same on the other side
