gse2schmidt
- Oct 21, 2008
Had an issue about a month ago. The engine starts then shuts off in about a second. All the gauges work, I can see RPM's while it fires. I can hear the fuel pump start during key on and sounds like its running for a few seconds after it stalls. No security light after the inital light up of security light before key on. Last time the wife tried to start it with the remote(aftermarket clifford professionally installed with passlock or passcode bypass module). Then I played with the remote start on and off, key on and off and all of a sudden it started and ran fine so it's not like a fuel filter clogging or regulator going bad slowly....right?
Anyway a week ago it did it again and all of a sudden it started and ran great until today and now nothing seems to make it better. disconnected the battery, tapped on the relays and checked them for corrosion and even swapped ones with the same serial numbers between the fuel pump and stuff then back again.
So now do I take it to the place that installed the remote start or my mechanic.....seems like I should be able to start it with the key or if that passlock/or passcode bypass module possibly hosing me?????
Seems like if the engine fires the crank/cam sensor must be working.
ignition module?
anybody out there have it happen to them?
