High Rpms but not moving
Sudsmcduff
hi. Just picked up a 08 Tahoe hybrid. Occasionally transmission seems to slip. Was at 2600 rpm and was not moving at all. No grinding noise. Happens 1 once a week. Thanks for any help. also getting high rpms sitting at a light. does this mean its charging batteries?
bladenbullet
SW Florida
if the gas engine is running at stops it is to charge the batteries...otherwise there would be no noise at all...short tripping a hybrid can lead to lessened fuel economy and more frequent gas engine activation as the batteries are not obtaining full charge...not sure about the slipping....can you give a more detailed description?...are you sure youre not perceiving a slip because you are running the gas engine more and hearing more noise?...
