High beam tap location needed
packy41
Looking for a good place to tap in for the highbeam circuit to control a relay for aux lights.
It CANNOT be at the headlight itself or tapped into either, but a common + wire. This is due to using a headlight flasher on the 2012 PPV (when one side comes on, it will flash the accessory all on/off which doesn't work) :)
Thanks
