Help
screamin chicken
Beaufort, SC
When I get into my Yukon the drivers side mirror is always pointing down, I had it set and when I push 1 it does nothing and I have to manually adjust it up.
johnebgoode
Long Island
Set mirrors to where you want them and push the #1 button and hold it till it beeps twice. That will set the mirrors to that position when in Park and Drive. If you dont want them to move when in reverse then do what Rollin' suggested and turn off that option.
screamin chicken
Beaufort, SC
I have set the mirrors to where I wanted them, and I heard the beep twice but for some reason my drivers side is always a tad down when I go to drive it, and when I push the 1 setting it does nothing until I adjust it myself. What is the curb view...
bshack88
Key fob #1 will set the driver side settings to setting #1 and key fob #2 will set them to the #2 setting so it is possible you are actually using key fob #2 and thus every time you use your keyless entry, you are setting the driver side to the #2 setting.................. was that confusing or did it make sense?
Tahoe07
PA
I thought it mught be the #2 fob too.
Just set the mirrors etc the way you want and press and hold #2 until it beeps.
I set both of mine the same so no matter which fob I grab it will be right. I almost ALWAYS drive mine so this works for me.
