Help with Interior Removal / pic
treepete
Genesee Twp, WI
How does this seat belt cover thingy come off? can the cover be removed, or does the whole assy need to come off? (to remove the whole assy, the super-big torx bit is needed., i think) If so what size it that thing, 52?
blk87brd
Castlegar, BC, Canada
It has to come off with the assembly. There should be a plastic retainer holding it in place on the inner surface. Once that is removed you should be able to get a driver in the Torx seatbelt retainer bolt. You may want to soak the bottom of the torx bolt with WD 40 before you attempt to remove. If I recall, mine are T-50. Use a solid torx not one with the security hole in the centre. I used the one with the hole (Grey) and broke it right off the bat.
