Help installing dvd head unit
nicholasscheuerman
I am supposed to splice a wire to my parking brake switch but I don't know exactly where it is. I am assuming it is right behind the parking brake but there is so much other stuff up there. Do I need to disable the airbag system to do this? And, should I go ahead and bypass the parking brake and just install it on a 12v accessory wire in my fuse block so it can play video's whenever? I have a 2001 Tahoe w/o Bose w/onstar.
718frankb
BROOKLYN
just ground that wire with a switch in between that will make the unit think the parking brake has been applied. if you need a foot brake input it is a white wire off of the brake petal under the dash hop this helps you . for more wiring diagrams check out (THE12VOLT.COM)
718frankb
BROOKLYN
dont connect to 12+ you can mess up your head unit parking is 12- also you dont have to disconnect
the air bag just remove the ground from the battery ,to be safe--but i never do !!!!!!!
