Help changing the turn signal switch on a 2008 Tahoe
BillMoulton
Has anyone here replaced the turn signal switch on a 2008 Tahoe ?
I have the new part but not sure how to remove the lower kick panel and the steering column cover without breaking them. Any tips ?
Semajeep
I need the same info, I can remove the lower kick panel and the top of the steering wheel bezel, just not sure how to remove the lower bezel without breaking it. Seems to hang up on the steering wheel height adjustment lever, any ideas on how to remove the lever so I can get the trim piece off?
Semajeep
Just in case anyone was wondering, if I gured out that adjustment lever on the steering wheel will pull straight out, then you can remove the lower bezel.
