Hello All,
Here is my story I have a 99 Yukon with a 5.7l and over the summer it felt like it started to misfire ,the plugs were fairly new so I changed the cap,rotor and wires that seem to take care of it.
Then about a month ago it was giving me trouble starting so I changed the plugs that helped a little then it had a couple of codes p0161 and p0135 so I changed the sensors and still the same thing and the check engine light comes on and off but if I put jumper cables on it it starts with no problem The battery showed to be a little weak and that was replaced as well and also the PCV,fuel filter and airfilter were replaced as well as new plugs but yet the same thing its hard to start and after awhile it starts and the truck never not started but at times it needed to be jumped while it is running it runs fine.
Any Ideas
Thank You for any help
Any Ideas
