bzbatl
I have a strange problem that I haven't had time to let the dealer take a look at. I'm not getting any error codes in the dash LCD.
2001 Tahoe 5.3
I used to have the common issue of the heat getting stuck and having to let the truck sit for a while to get cold air again, but now I'm not getting any hot air... sort of.
When I first turn on the truck, it blows cold air for a good while (45 minutes in a 30 degree commute). Finally the heat kicked on for about 10 minutes, then went away again.
I noticed that my temp gauge spiked to about 240-250 when the cold air was blowing, and dropped right to the center at 230 when the hot air was blowing.
Is this an issue with the thermostat or that heater core thing under the kick panel?
2001 Tahoe 5.3
