Headlight Questions
evenflow76
Pennsylvainia
I have been tossing around the idea of changing out my headlights for projectors with angel eyes. As everything else i can spend as much money as i want on a set and i am sure there are quality differances. Most of the cheaper sets i have seen end up with water inside the lens after awile, my question is this....can i get some silicone and seal the seams of the light to protect them from condensation or should i stay away from a set like these http://cgi.ebay.com/ebaymotors/00-0...213992630QQcmdZViewItem?hash=item150213992630 all togeather? if they are junk, what should i be looking for?
Also if i go to clear corners (this set has them included) what do i need to do about turn signal bulbs etc. to be legal? and again if there is something better what are they?
are you guys running projectors seeing an increse in visability, or did it stay the same? I dont wanna make it worse and sacrifice visability for looks, i did that with my last vehicle and it wasnt worth it in the end.
opdenali
With clear corners i have some chrome Stealth bulbs. You can't see them when they are off, and they are amber when on.
