Head Unit Dead after installing Bluetooth
gbt1976
Hello
I have an 03 Yukon with the factory Bose stereo. I installed a Parrot CK3100 Bluetooth with the harness to plug into the factory head unit. Everything was working fine with both the radio and the bluetooth. Then i unplugged it all to run the wires behind the dash and when i hooked it back up the radio does not turn on. I pulled out the radio and hooked it back up to just the factory harness and it still won't turn on. Is it possible that some anit-theft device was triggered even though I have had this radio in and out many many times with no problems? Could the radio have been damaged while i was doing this install?
Thanks for any help no this.
Greg
Sinjin
This may be a dumb question. But did you check the fuses?
