head light problem
diesel1114
long island city queens ny
hi guys i was driving the other night in my 97 and i went to switch to high beams and lost the headlights completely, only headlights i have now is dayitme running lights which im using for my headlights, if i turn switch to headlight position no headlights or highbeams or anything, put it on position for parking lights and daytime lights come back on but still no highbeams or regualr headlights, so did the highbeam switch /turnsighanl switch go or did the headlight swtich go ? i saw that that headlight swithc has some kinda board in to control highbeam / lowbeam/ daytime
anyone have this problem and any suggestion
in need of help
john
nyc
pchapin
I have the same problem, except I do have high beam in the lights on position but no low beams.
inthechateau
Aberdeen, MD
I'll bet the turn signal multifunction cluster switch failed on column. Believe it or not. All light functions go through that turn head light dimmer control switch.
pchapin
I figured out my problem. One of the wires, the one for low beam, had pulled out of the plug on the multifunction switch. It looks like years of tilting the steering wheel up had caused it to come loose. I was able to get it back in place for now. Not sure how long it will stay as it is a little hard to get at without removing the steering wheel.
