hanging brake line
notch8
My rear brake line looks like its a little bit to low, its about a foot or so off the ground and looks like the spare tire should be holding it up, but I don't have one because the mount is broken. Is there a piece missing or can i tie it off to the frame, it doesn't look to good the way it is.
Jeremy_K
Northeast, PA
If it's on the driver's side, that's normal. Not sure if it's a brake line or not but it has a rubber conduit around it and it hangs a little low. I've noticed it on every Yukon and Tahoe in the same position.
oneradride
Omaha
I concur, bugged me also but when I looked around they are all like that, I think it’s for the e-brake…..
