Hey everyone
I have a 96 Tahoe 2dr 4wd
Its throwing 2 codes right now
1) P0700 tranny code, I hear this could be a problem with the TCM and or PCM. How do I know which one is the problem? They are 2 different computers right or is one inside the other?
2)P1100, not sure what this one is?
Also something else was noticed while trying to pass emmisions. The computer was not holding memory. The emmisions guy drove the truck around with it hooked up to the OBDII reader and the computer would register what was going on but as soon as you turn the key off the and check the OBDII reader again 5 things would go back to the NOT READY status.
Sounds like a bad PCM but not sure. And if the PCM is bad do you think that would help with the P0700 since the code is for a PCM and or TCM?
Thanks everyone any info would help out great.
Where can I get a new TCM and or PCM?
Bernie
Bernie
