GM exhaust w/ corsa tip
allando
Hawaii
Does anyone know if the corsa tip can be used on the GM perf. exhaust? Reason is because I can get the GM exhaust for cheap, but I really like the looks of the corsa tip.:cool:
allando
Hawaii
But GM doesn't have those dual tip styles like the corsa though.....
Gambler
Baltimore
It will be the same diameter pipe, so it should work just fine.
73shark
KC, MO area
GM Perf. exhaust is 2 7/8" diameter and is made by Borla now for the NBS.
allando
Hawaii
From what I've seen, the corsa exits at the rear, I wonder if they sell side exit type so I can use it w/ the GM.......
Gambler
Baltimore
I thought it was the other way around, are you sure?
Regardless, just get whichever exhaust you want and order the tip. As long as you get a tip for the proper size pipe you'll be fine.
73shark
KC, MO area
Yep, talked to both companies. Corsa used to make the GM Perf. exhaust.
