Giovanna DBL-G 405's 20x9 on a 2007 Tahoe?
Don'tBurntheDay
Sorry if this question has been answered already....
Can someone tell me what width rims fit on a Tahoe? I think I have read that it is betwee 20x8.5 and 20x10, is that correct? I am going to look at some Giovanna 20x9's later and wanted to know if they will fit my Tahoe without rubbing or any othe rissues?
Thanks in advance. The Tahoe is 2wd.
RIZZ
20x10 i have 24x10 on my truck but i think it can fit 9.5 too
Don'tBurntheDay
This post is kind of confusing. I know the Tahoe can fit 20x8.5, and you're saying you are running 24x10. So anywhere in that range is fine?
RIZZ
I would say so...double check with a rim shop tho
catnhat fan
I am also looking at the same wheels. They came off of a 2003 Escalade EXT and I am not sure they will fit my 07 Yukon XL Denali? They are 305/45/22 Double G's with Toyo Proxes tires and from other posts on this forum, I believe that size will fit without any rubbing. I believe the bolt pattern is the same from 03 to 07.
Let me know if yours work out OK.
Good Luck
JD Larue
East Bay, CA
I have 20x9's on my 07 Tahoe. They should fit as long as you stick with the factory offset and backspacing. Stock backspace is 31mm and offset is 6".
kmg3773
Yeah they should fit fine, i have 24x10 Boss 333s with a 32mm offset. Yours should fit just fine.
