so when i bought my 99 2dr hoe the fuel gauge never worked right. it shows accurate but has that ''hummingbird buzz'' to it. the oil pressure gauge read higher today than what it usually does and the water temp and voltmeter seem to work fine although it looks like the water temp wasnt clocked back right when the gauge face cover was changer out to a white backing and tealish color lit up. my main concern is my is the tach that will ''hang up'' frequently and jump many rpms when i make a hard pull. another thing the transmission squeaks when it shifts gears at high rpms when i am on it. it has corvette servos in it. thanks in advance.
