Gas Leakage???
sasquatch094
ohio
Hey alrite, so today i filled my tahoe all the way up with gas. then after that i went to my shop put her on the lift to replace my starter. Well when it was about 7 feet off the ground the thing started to leak gas back by the gas tank. i was looking around and it seemed like it was running off of the top (meaning 2 lines the top most one from the frame rail) and then dripping on the floor. Does anyone think it could be maybe a Vent, i filled the hoe up more then the pump wanted it to stop at. I said 60 bucks to the gas station attendant and then went out and i spent 59.02 $.. and i wasnt about to go back into the gas station so i just held the trigger and let the other 98 cents go in. Is this why its dripping back out, bcuz its filled to much or what?????// All the fuel lines are brand new by the way... Thanks every one :thumbsup:
GMCYukalade
NC
might want to double check those lines - there isn't a vent
sasquatch094
ohio
what do u think it is then?? its only done it since i filled it all the way up..
96ProCompTahoe
Indiana
if it was vented it wouldn't release pressure when you open the cap on a hot day. has to be a leaking line.
i would put my money on the pressurized line going to your engine
sasquatch094
ohio
Do you think it could be just that its full and at the top by the sending unit somehow its spirting out?? idk what to say.. alllll brand new lines and everything. and its only done it while i filled it all the way up.. : /
96ProCompTahoe
Indiana
i've put a few extra bucks in mine a couple times to cut it even and i've never noticed any leaks on the driveway.
GMCYukalade
NC
The only way it would come out around the sender unit is if it wasn't seated properly and the o-ring wasn't on it all the way - so id rule that one out.. - unless it didn't seal good?
sasquatch094
ohio
ahh sheit i have no idea. but today it stopped leaking and was still on the lift from 3 days ago?? wth man..
mary900
Adams, TN
Eliminate the possibilities. On the next couple of fill ups, don't overfill. If it doesn't leak, then try overfilling. If it leaks you've found the cause.
