spuonme_lm2
About a month ago, I lost my fuel pump, (of course always on a half full tank of fuel). Luckily I was in my driveway. So I dropped the tank and replaced the fuel pump. Not a problem, put it back together and it worked fine, not great but ok. Well I started noticing that, it doesn't start nearly as well as it did before, and I have no power after about 3300 rpms also, its like the fuel is cut off. also now it misses from time to time. Now to find out the reasoning with all of that..... When I dropped my tank, which I had never done to this vehicle before, I didn't take off the fuel lines that went to the pump on the top of tank. So when it came down it bent them, the hard black plastic lines. So that is why I think that I can't turn any rpms. But I know that I have to have a certain PSI in the fuel lines for my motor to even run. So how can I achieve that PSI if my fuel line is crimped. makes no since to me. Also I can not hear my fuel pump turn on unless I am cranking on the motor, it does not come on when I just hit the key. So my second thought is that my distributer is going out, my truck has 127,000 miles on it and I am the second owner and I know that it has not been changed, also probably need to do plugs and wires. So anybody have any ideas. Also, I have a Hypertech chip in there and it doesn't throw any codes. Please help
Thank you
Thank you
