ferricsteed
- Aug 6, 2012
Who is the moderator? I am expecting a reply.
I got a question for the techies. I have a vibration in the front end. I removed the front half shafts. Simple question: will the front hub fall off with wheel attached without the half shafts installed? Does the big nut on the half shaft also hold the hub assembly together? I want to drive the vehicle to see if the hubs are nosiy or if the front pumpkin is noisy.
