RyleDup0766
99 Tahoe LT 4x4 4dr
I've got a shake in my front end and steering wheel at around 32mph up roughly 40mph. It's a little hard to explain, but it pretty much feels like a broken belt in a tire or loose lug nuts (That's just an example of how the shake feels). I do have a little play in my pitman arm, but not much. My ball joints, wheel bearings, and tie rod ends are all tight. I had my tires rotated and balanced to see if that was the cause, but no change. I had someone tell me it could be warped rotors, but only 25% of the time does the shake get worse when im braking. Is there a common thing that causes this shake? Or any other ideas of what would be causing this?
