front door tweeters
96cherry
livonia
has anyone put any aftermarket door tweeters in the spot by the window switch. if so let me know what kind and how it turned out. i want my indoor speakers to scream.
sasquatch094
ohio
I believe the tweeters are 1inch. and any tweeter out there wont fit right in, you have to mod em up a little bit, meaning with wood or some other material. Best thing would to disconnect the factory ones and then put some new (any size) into the A pillars on each side either facing you or not. If you know how to fiberglass your in good luck, have em pop out a bit pointing to the rear of the truck, if u dont know how to fiberglass, just cut a certain hole in the A pillar and stick em in with a cover over them.. good luck
95ThAHOE
CT
yeah i put mine up on the top of the door panel near the pillar and it faces at you pretty good, didnt feel like trying to get them to fit in the stock position
96cherry
livonia
i think im going to go with putting them at the top of the door panel, did you just tie into the front dor speaker wires?
GMCYukalade
NC
Wow, i'm kinda surprised i'm not the only person who done this, mine are at the top of the panel as well, near the pillar pointing right at the ears.. tied into the front speaker wires
Biggwaukegan
yep i replaced my tweets and needing a little modding. put some component alpines and they scream like a kid in the doctors office:smilielol:
qlc1964
st.louis mo.
i changed my doors spkrs to kenwood coponents i use my hot glue gun
to angle the tweets toward the listeners under the stock tweet grill.
tweets still in the same spot quick& easy
Biggwaukegan
im ordering some tweets off ebay to go up high somewhere. im gonna have some serious screaming going on here boys.
GMCYukalade
NC
Here is my current setup....
8 Tweeters (2 factory) 1 on each of the door panels at the top close to the Pillars pointing at the ears.. - 2 on the Very Way Back panel behind the rear 4x10s pointing frontwards - (1 on each of the pioneer 4x10s - so does that count as 10 tweets?)
2 front door speakers (blown as of current, and un-hooked looking to get new ones, not wanting to go factory - will probably get those speaker-pods i've been seeing)
2 rear door speakers factory (factory amp)
2 way backs 4x10 pioneers
2 15" Memphis M3's - 1000d Power Reference Class D Amp
Clarion Head
Biggwaukegan
:bubu: Ok heres a little taste...4 tweets plus 2 on the way as of today...plus my cerwin 12s plus my super coveted old skool r.fosgate punch power amp, that cranks harder than any amp ive heard to date, plus all the components all the way round, plus the all hell my ride will blow the panties off your dead grandmother...im out:smilielol::10s:
