JC150
What size tire to you use? I have 22's and I'm thinking of upgrading to 24's. And I'm probably going to keep it at stock height.
isn't a 35 series a bit thin? while driving around does the ride feel rough? since i was going to keep it at stock hight, i was wondering if a 40-45 series might work without rubbing
The sidewall is a little stiffer, but ride quality did not suffer much at all. Still a decent ride; much better than I expected. If you go with a higher sidewall ratio, you may run into problems with the tire rubbing on the inner fenders, especially in tight lock-to-lock turns. And the ride quality difference between 35 and 40 isn't going to be enough to really notice.
Hey JK I have 23s and my driver side tire rubs on the inner well,it actually rubbed through the fender well,only on a hard lock to lock turn and more in reverse,was wondering if its going to get worse with 24'' wheels. Just like you said if you go higher with the tire size it will rub.Jk can you measure the height of your 24s I would like to compare them with the 23 inch tires.Thanks!
Overall diameter is right at 32". Width from sidewall to sidewall is 12". Backspacing of the wheel is about 6.5".
Not sure how to measure the backspacing,my guess would be from the back of the hub to the backside edge of the wheel?Thanks againatriot:
Tire brand also has a big impact on ride quality. I have TOYOs on mine. 285 40 24s. I have ridden on tahoes with 35s on Falkens and they felt like you were on all rim. Mine feels pretty smooth. Its stock height. The wheels would look bigger and the truck would look tougher if i lowered it but I drive it everywhere and im better off leaving it at stock height. They rub very little only when im backing up and i turn the wheels all the way. Here's a picture...
