Can anyone out there PLEASE tell me if they've ever changed the high beam bulb (drivers side) on their '15-'18 Tahoe? My hand is just a tad too big to get the cap off. The only way I see as if you remove all 6 bolts on the black plate above the the washer tank, remove the 2 bolts securing the fuse box (which you can't access because of 2 HUGE permanent plugs on each end of the fuse box) and remove the plate. This gets you about another 1-1/2" to get a hold of the cap so you can twist it off. Other than that, it's removal of the entire front bumper cover because of a SINGLE bolt fastening the headlight behind the bumper cover! Ridiculous design!
Any help or people who have experienced this or knows the answer...PLEASE chime in!
