I actually have 2 questions. First, if I wanted to run power for an amp to the battery, where can I go through the firewall on a 1999 Tahoe?
Second question (long), the reason I want to go through the firewall is I have a leak on my drivers side that I'm not sure where it's coming from. A while ago, I ran this amp power cable from under the back seat, under the carpet, out into the door wiring boot, and i cut a hole in that boot and ran the wire out there to go to the battery. the hole is on the bottom of the boot, so water would have a harder time getting into it, but it still could, I guess. would this little hole in the bottom of the boot cause the carpet on the drivers side to be wet every time it rains, or could there be another problem? (i know i probably shouldn't have wired it that way in the first place)
