performance1985
- Oct 8, 2011
Since I just found out about the overwhelming problem GM has with the exhaust manifold bolts shearing off in the heads, I now need to replace my manifolds. My 06 has only 59k miles on it, and three bolts sheared off - #1, #7, & #8.
It's amazing that GM knows about this huge problem and won't do anything to help fix it - except take our $1100 to repair it. They acted like it was the first time they heard of the problem.
Off my soap box for my questions: the bolts connecting the downtubes to the manifolds, do they need to be heated up to break the nuts loose? Someone in another forum mention that GM uses a yellow threadlocker on the rear brakes - which needs to be heated to break-free.
Also, anyone pulled out sheared bolts from # 7 & # *8, with the heads still on the motor; or, do they need to be removed - due to space.
I ordered Doug Thorley Shorty's to replace, and no way I'm paying the dealer to fix.:flame:
