Escalade rear taillights in a Tahoe?
blk450er
I've got a 2011 Tahoe and want the rear led taillights of an escalade of the same body style. They look like they are the same design. I can have access to a set. If they do bolt right in is there any modification to the wire harness or do the hook right up to the tahoes factory wire harness?
NathanJax
Moderator
Jax Fl
They bolt right in, but you have to modify the harness to work with it. Escalade has 5 wires and Tahoe has 4 and the Esky LEDs will make your turn signals hyperflash without modifying the harness
You would also need the rear appliques (above the tail lights) since the Esky tails have the outside line going up them
blk450er
I ended up just getting the eBay esc look a likes for the Tahoe. Don't have to mess with the wiring, they simply plug n play and look identical to the caddy. Oh and are way cheaper. Had them since Christmas and love them
NathanJax
Moderator
Jax Fl
Good choice. I've had my G5's for almost 2 years now with no issues and are exactly like the escalades
