Engine dying on me...
TrueNorthAK
After a couple of cranks from my battery, my 99 yukon will turn over, but after I put it in gear and give it gas the engine will die. I will still have electrical power when this happens, and will repeat this two or three times, then the truck runs fine and gauges read normal, is this an alternator problem? I am full on oil and fluids, I just bought the truck 148K and new I would need a new battery from the first couple of starts, the engine just started quitting on me within the last couple of days. Any advice?
DJTricky
Robbinsdale,MN
you might want to go to a parts store with your alternator and get it tested, if not them it could be some wiring.
