electric cooling fans
jodadair
Sussex, New Brunswick
G'day,
Does anyone know of a good aftermarket or stock electric cooling fan set-up to replace the stock belt-driven fan ? Seen a friend of a friend use a late-model dodge truck hemi electric fan that was almost a drop-in (he put it on a '95 chev truck). He just bolted it to the shroud and added an adjustable thermostat. looks pretty sweet and he got it off of a wrecked truck.
Acclereration is definately improved (i'm not sayin' whiplash better, but noticable), so does anyone else have any experiance with electric fans ?
treepete
Genesee Twp, WI
Welcome to the forum.
yeah I did an electric fan install with 95TwinTTs help. ( amongst other guys, too :) )
you can read the thread here.
I did notice a gain, but not so much in accelleration, but rather in engine temps, and also in mileage for sure. just for my normal put-putting around i used to get 325, now its more like 360. if I hang out on the expressway for a whole tank, I can get 400+ miles.
I kinda watch how I drive though, which might inflate the percieved results.
but yeah. electric fans are far superior cooling wise, and reduce parasitic loss from the engine having to turn that big-ass fan/clutch assembly. It make more room under the hood and looks waay cooler. On Del's advice, I went with the Perma-Cool, but flex-a-lite also makes a drop in unit.
Install is easy, and generally speaking, Im mechanically declined. :D
hope that helps you,
Pete
qlc1964
st.louis mo.
the only draw back with the elec fan you will need the charging system to handle
the current draw from them.
treepete
Genesee Twp, WI
good point. I think mine slaps an extra 19-20 amp load on the system when it runs. Dont over-tax your alternator.
JennaBear
CA
Just get an overdrive pulley and problem is fixed. I threw in a larger fuse too just in case.
qlc1964
st.louis mo.
you mean a under drive pulley? it will be smaller than the stock one is thus making it
spin faster while idling. the alt bearings will have a shorter life plus it will make a
almost a whistling sound. i know!!! i did this to my alt
treepete
Genesee Twp, WI
can we talk about this a bit more, im interested in understanding the pully thing more in detail. you actually add another pully, or change the size of one of the pullys?
JennaBear
CA
Nope, the one I am using is an overdrive pulley which is smaller than stock, making it spin faster. This is the one we sell with our e-fan harness.
An underdrive pulley is bigger than stock making it spin slower (underdrive's the unit).
JennaBear
CA
I just changed out my pulley, quick and simple.
treepete
Genesee Twp, WI
please forgive me, but what pully? the alternator? what is the gain then if it spins slightly slower? Since Jodadair isnt coming back or something, Im just stealing this thread. :D
JennaBear
CA
Yep, it is just the alternator pulley.
There is no gain from spinning slower (underdrive pulley). The overdrive pulley spins it faster to boost amperage at idle and low rpm.
JennaBear
CA
Not a problem! That is what we are all here for!
qlc1964
st.louis mo.
yeah!!!! reading that overdrive pulley is what it's doing to the alt instead of under drive.
mi bad
