DTRL (daytime runnig light)
johnebgoode
Long Island
The DRL's dont go on till ya put it in drive. I noticed that on mine. If they still arent going on check relay. There should be a labeled relay for the DRL. Probably located under hood. Check manual for relays and fuse locations
Just throwing this in, but GM has a RPO option for DRL delete. Is it available on the nbs trucks?
DRLs should come with the parking brake off and the vehicle in drive.
Getwired
DC Suburbs
Also, for what it's worth, fuses 30 and 32 (at least on Yukon Denali) control the DRLs. You might want to check and see if they're installed at all per JK's reply above...
