Ta2ed Texan
- Feb 22, 2012
Ok so if any of you have read any of my recent posts. I have a 97 tahoe 4x4 that I just put a brand new crate motor in. When I say new I mean 0 miles. So I get this motor and swap over all the pulleys, brackets, accessories from the old motor. The upper and lower intake as well as the fuel injection. I also kept the distributor out of the old motor, and all the sensors ( a couple of them broke but I have replacements). So I get everything put together and was getting the p1345 code (I think thats the number, its the one where the cam and crank sensors dont match up) and a p305 which means the number 5 cyl isnt firing right. I had a code for the evap system, one for an o2 sensor (at the time I only had one upstream sensor plugged in) So I was looking up info on the 1345 because after reading about how these motors are timed and all that. My thoughts were that the miss was probably related to the cam and crand sesor issue. So I replace the distributor and the `1345 code goes away as does the 305. Now there is a p300 code. the only parts of this morot at this point is the fuel imjectors. I got the new spider assembly that actually has injectors instead of popppits. How ever I dont want to put it in unless I absolutly have to. So what do you guys think? I really cant afford to replace all the injectors. Is there any thing else I can looks at. Like I said this is a brand new engine so we can rule out anything engine related. Not all of the o2 sensors are hooked up, I think 3 are but one isnt I know for sure. Would this cause such a rough idle? I am going to hook up the other sensor just to make sure
