markdtn
I have been lurking here for a bit and really enjoy the knowledge that you all share. I bought an '01 Tahoe with the factory fog lights about 4 months ago. I really love it! I had a '95 Suburban before this, but the Tahoe is an order of magnitude better truck than the 'Burb. It has 170k highway miles-still the original water pump. I bought a new one from GM and I carry it with me.
Anyway, on to the questions. I have gotten a good deal on some Hella 70mm driving lights with H9 bulbs and am quite impressed with the light they put out. I have a few questions so I hope you can help. I searched for the answers, but did not see an exact similar question post.
1) Can I use the Z71 lower valence (GM p/n 15766483 - Air Dam) with my stock chrome bumper? Anybody used aftermarket 2 3/4" diameter driving lights with it? I see I will have to do some cutting and make a bracket to mount them.
2) Fog light fuse is 15 amps. An H9 bulb is 65 watts so 2 would be 130 watts. Amps=watts/volts so if I use 130 watts/12 volts I get 10.8 amps so the stock wiring should be sufficient? I know I will have to change plugs.
3) I have seen mention of an auxillary lamp switch but the Factory Shop Manual does not mention it that I can find (8-299 fog lamp schematic, 8-496 exterior lighting info). Is there such a thing? How does it work? Will it allow power to the lights with both high beams and low beams?
4) Finally, should I give up on all this and just buy better headlights?
Thank you all in advance for your help.
