Door locks going crazy....DIC Message
dminer
Riding down the road and all of a sudden i get on the DIC "Drivers Door Ajar" which it was not..... and then the door locks, by themselves, locked and unlocked about 7 or 8 times.... happened a few times in a row.... Any ideas??? Thanks
dminer
ok, heres an update. Now that I have the truck back, My wife had it, It seems that the truck dosent know when the drivers door is closed. The interior lights stay on, they will not dim and then go out as they should from closing the door. the key in the ignition will continue to chime if you close the door and stand outside, you can hear it. It seems like the door is still open though it is shut. Can anyone tell me where the switch might be that controls that function?? Thanks
dminer
another interesting thing. when i put the power window up or down, when it reaches either full up or full down, the chime goes off and gives me the door aja message and the locks un lock. when window is all the way up, you can pull up on the switch and get it to do the same thing. anyone????
Switch Doctor
Atlanta
Make sure when the door is closed that the door ajar switch is being pressed in all the way, you can do this by putting something between the switch and the door so it's getting pressed in all the way...I had a vehicle that did this and found out it wasn't going in all the way. Far as the locks moving by themselves...Sound like maybe water got it in and was causing it to engage..Should be fine once it dries out.
http://www.switchdoctor.net
