vash
I just got a 99 Tahoe LT 4 door 4x4 last Saturday and I've started doing some maintenance to it. It has just over 209,000 miles on it and it sat for a year and before that I'm not sure. So far I have done new e3 plugs, 8mm wires, cap & roter, map sensor, maf sensor, egr valve, acdelco serpentine belt, K&N fuel filter, specter air filter, royal purple oil and filter, and seafoamed the old fuel and ran premium. I was getting just over 13 mpg before I started the maintenance hopefully a little better after. I'm planning on getting o2 sensors, tie rod ends, ball joints, bushings, shocks, brakes all around, and rebuild or buy a rear axle (the previous owner said it would need one eventually but I haven't noticed anything yet) also fix the ac by next summer. Is there anything else that I should do? Any issues these things usually have? Also I have a brake line leak somewhere in the rear but have as yet to find it but I need to fix before winter hits!!! Is there anywhere that is typical for this to happen?
