Careful use of a heat gun takes them right off. Grab each letter/badge on the edge with needlenose or other pliers. No need to pry under them, the glue melts then you clean it up with goo gone or WD40. Worked fine for me, no paint issues.
Yeah I did the same with my wifes blow dryer. I heated it up and removed them with a squegee. I then used bug and tar remover to wipe off the excess glue.
