tahoesteve
Took my 2012 Tahoe LT to the dealer because the transition from 8 to 4 cylinders caused the truck to vibrate, especially at low speeds. A tech rode with me and agreed that it seemed excessive. Returning to the shop and reporting to the service writer what we found, he reached in drawer and pulled out a SB that sez it's normal. The tech said he found an update for the computer that would change the transmission shift points but it probably wouldn't adress the vibration. I like the way it shifts with the new settings and it seems the cylinder transition is a little less bothersome. I realize I'm not the first peson on the forum to bring this up. However, if your vehicle qualifies for the computer flash, you might want to consider it. Essentially, it shortens the time between shifts.
