teamheeler87
- Aug 20, 2017
Today I was driving on a county road with my wife when we came around a corner to a dio in the road. It was marked DIP but when we got it, it was more like a ditch. So bad it snapped my CV axle. Not doing my research thoroughly, I removed the axle from the tahoe and started to drive home thinking it was fine without the axle installed. I was dead wrong and ended up almost losing the wheel and ruining the wheel hub. Long story short I replace both the CV shaft and Wheel hub assembly on the side of the road. Now when I hit the brakes the traction control icon comes on as if I turned it off and the stability control disabled display comes on. Mind you I bought a Moog wheel hub assembly and it came with a new sensor line which I did not install. I just used the factory one. But tomorrow I will remove the tire and try that but I don't see how that would affect it.
Any help would be appreciated.
2006 tahoe with autoride and 4wd.
